C320 4matic. Saaaaaave me!!
So I bought a 03 C320 stuck in limp mode and won't get out of first gear and havent been able to fix it because the OBD2 sensor wouldn't power on. The battery is draining as well and I have to jump start it if I havent started it in a day. I've narrowed it down with some investigative work and this is what i've found so far.
I pulled out the entire ECU to check it, had two bent pins that I fixed back and checked the OBD2 sensor again with no results.
Checked the continuity of the OBD2 pins. 7 and 8 had 12 volts, but 16 did not.
So i'm currently trying to check the resistance/continuity from the DLC to the SAM module pin 11.
Unfortunately i have limited knowledge of these vehicles electrical systems and not sure where pin 11 is located in the SAM module.
Can anyone give me any additional information on where to look and a SAM diagram that could possibly break it down?
Sounds like someone has monkeyed around with it before. Disconect the battery for 5 minutes then reconnect it. Sometimes that's all it takes. The fast drain is likely the power seat modules. Disconnect the power supply from the seats and see if it still drains. There's a quick and dirty $5 fix for this common problem.
Limp home mode could be ATF contamination in the TCM. Pull up the passenger side carpet and check the TCM for ATF.
Then it's very likely that the TCM is water damaged. It can be replaced, it's not coded to the car. Find one with identical PN. You'll still need to hook it up to a scan tool to clear codes. Water damage would also explain OBD2 OBD2 not functioning. With water in the wiring harness you're in uncharged territory. Good luck.
Make sure the car is out of the rain, and can dry out completely.
Water plays havoc with these cars...mine has died twice
from water getting in after rain. I'm quite surprised I haven't had any trouble recently
as here in NorCal it's been raining off an on for going into the 3rd week straight.
Very happy it hasn't!
Wiring diagrams are available on WIS and hacked copies are available on Ebay and or the
W203 Service DVD. Service DVD used to be sold by Mercedes directly from
their literature dept.
It was originally designed to work on XP and was ok on Win 7,
BUT I recently switched to Windows 10 64 bit and found instructions to get
it working, but haven't been successful in getting the wiring diagrams to work.
I posted on this recently, just look in my profile at my recent posts.
And as mentioned or not, TCM is under the right side footwell, super easy to access.
And yeah, easy to get a replacement on ebay, and thankfully not expensive.
As mentioned just match the pn exactly!!!
Hard to troubleshoot with a deal OBD port!
Im assuming if it has voltage the fuse is ok, but in case you didn't know, it has it's own fuse.
Start with the basics. Check all fuses. Get a battery that works. 12v isn’t enough, you also need amperage. Check for a draw with an amp meter. You need a scan tool capable of accessing the body modules (Sam) and/or tcm to reset limp mode. Disconnecting the battery won’t work. There are connectors (forgot what they’re called) that you can access under the interior trim. Theyre for checking can bus communication . If you seen water. Pull all the relays and fuses out in rear and front sam, I’ll bet anything they are corroded. You need schematics, you can get WIS for 10 bucks on eBay and a bi direction scan tool for around 200. You can bypass the power issues by pulling the power wire from DLC and clipping it to another power source.
ah damn too late sorry
So the OBD port is still not working, i don't think its a fuse but i think it might be the Sam console. im going to replace the entire thing and work my way down from there.
