M271 Oil leak between Timing cover and Head Gasket
Old Feb 25, 2020 | 09:35 AM
w203ck's Avatar
2006 C180K, 2004 E200K, 1996 Mercedes E320
Hi Everyone,
Hopefully I can get to the bottom of this issue I've been having lately.
I had the timing chain changed in my Kompressor engine W203 and ever since then I've been having an oil leak between the bottom of the timing cover and the head gasket, where the two meet. It's been leaking across the V shaped shelf on the front of the engine onto the RH side and onto the bottom of the sump.
I took it back to the place I had the timing chain done and they have told me it's the head gasket leaking oil. I am unsure to either believe this and replace the head gasket or just leave it as I am getting ready to sell the car in a couple of months?
Below is a picture with a red line pointing out where it's leaking from.
Any advice would be great. Thanks
And yes, the cam magnets are leaking but I've replaced them since and cleaned the area only for the leak show itself in the location I spoke of above.
Old Jan 30, 2023 | 12:56 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
I have a leak in the exact same location. Did you manage to fix it?
Old Jan 31, 2023 | 05:46 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
That sucks. I thought the timing chain can be completely replaced through the top?
