W203 engine clank and shudder in gear
Old Apr 4, 2020 | 07:12 AM
sjpenny's Avatar
c 180 w203 m271 2003
Hi, I have the w203 year 2003 m271 engine. 165 km on the clock
The engine is shaking and making a noise in the supercharger side of the engine, seems to be moving up and down on the airbox side.
The Video will give you more of an idea to the noise and shaking.
1st Video car is in park not in gear.
2nd video in gear.
I suspect the left engine mount or maybe tension pulley or maybe a cylinder miss fire.
Current pending code P00102 have had cylinder 2 miss fires codes before.
Timing chain plus intake valves were replaced a year ago due to the timing chain slip.
Idle pulley replaced 6 months ago totally shattered
The car has been running fine until this shaking problem.
The resonator hose did pop off at bottom the night before noise, I put that back on.
Any help would be appreciated.
Steve
