C230k 722.6 transmission fluid level changing too fast + mystery leak
When I measure oil level at 80C the level is changing too fast. If I measure the level after short drive when I monitor the temperature with STAR at exactly 80C, it is exactly between Min and Max but 10 seconds later is above the Max line and 30 seconds later is already on silver part of the dipstick.
It is possible that oil pump is not working correctly and when engine is in idle, the oil pressure is too low and the transmission fluid level is increasing and then I have leak from the breather which is on top of transmission?
The leak is not from bellhousing or connector and it is on right side.
I don't have any issues, it is shifting nicely.
Check your anti-freeze level.
It sounds like your radiator has a leak between the transmission cooler section of the radiator, and the anti-freeze section of the radiator.
That's a known problem with some MB radiators.
Since you see such a noticeable change after 10 seconds, another thing you can do is to drain the anti-freeze, wait for the engine to be at ambient(outside) temperature, then run the engine for 30 seconds, and only 30 seconds - not more.
If the engine is cold - outside temperature. You can run the engine for 30 seconds without any anti-freeze. It takes time for the thermal mass of the engine to gain significant heat.
DO NOT RUN THE ENGINE FOR MORE THAN 30 Seconds. And, only do that when the engine is ambient temperature.
Note: The Temperature gauge is not accurate when there isn't any anti-freeze, and hot spots develop quickly.
Good Luck!
If so, how long does it take? Just approx like: less than 1 min, ~5mins, hours+).
I don't know the fluid path in the MB tranny. I'd be surprised if it would raise the level. The fluid has to come from somewhere, and go somewhere.
Good Luck.
It's a closed system.
There's a vent for the pan/fluid, because it's not in a temperature-controlled vacuum. So, the air pressure(area) increases (when it gets hot), and reduces when it gets cold.
Good Luck.
