Help with part for 2007 C230 Sport rear brake line
Hope everyone is staying safe and sane during these trying times.
Recently the driver's side metal brake line on my '07 developed a leak so I ordered both rear lines from the dealer along with new adapters (75, 80, 105, 110) based on the attached diagram the dealer sent as a reference. However, when I pulled off the plastic underbody cover (along the left side) I found that the brake lines run from the ABS unit to the rear over the fuel tank and connects to the flexible hose as a single pipe. I lowered the fuel tank to see if the adapter was there but did not find any breaks in the line. Does anyone know if the '07 sport uses a single metal line or if they are indeed two and where should I expect to find the adapter?
Thanks!
Also how complicated is dropping the fuel tank please @arifk ?
