transmission pan drain plug stuck.
Old May 24, 2020 | 10:25 AM
mcc23's Avatar
C240
I've already broken 2 torx bits trying to remove it. Same deal with the pan torx bolts. I don't think its a torque issue. I think its a someone put this thing back on way too tight issue. Ideas?!?
I've tried penetrating oil and vice grips with no luck
Old May 24, 2020 | 12:31 PM
mcc23's Avatar
C240
Originally Posted by Plutoe
You do know that way to tight means that someone over torqued the the bolts. Have you used the correct sized hardened bit----bla bla
meaning my inability to get it off is not due to a lack of torque since the bits broke..........
I have new torx bits of a higher quality arriving today
Old May 25, 2020 | 01:53 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I once had a similar problem. Instead of breaking the bits, I began rounding the hole in the drain plug bolt. They use way too soft of a material (brass?).
My mechanic freed it up by spraying some penetrating oil, inserting a (correct) bit in, then giving it a few good whacks with a hammer. In any case, you probably want to replace the bolt once you get it off, as well as the copper crush washer.
Not sure if they've updated it, but the transmission drain plug uses a 5mm hex. The pan bolts are external Torx. Mine came off without any issue. FYI the pan bolts are one time use.
Old May 27, 2020 | 05:38 AM
Donald McPherso's Avatar
180 Elegance
Pella pump and suck the oil out.
