2005 Mercedes C230K aftermarket wheel size question
I'm looking at Niche Vosso wheels 19x8.5 front and 19x9.5 rear. Front offset 25mm and rear 35mm and I was wondering if you guys think they would fit. Tire size would also be 235-30 front and 255-30 rear. I know they would fit the rear, but mainly the front I'm concerned about is because the caliper is bigger in the front and I think it may hit it.
You can run this set up you will need atleast an 8 mm spacer in the front and possibly a 5mm in the back. I used to have this same setup and I scrubbed in the rear until I rolled my fenders. The front may scrub at deep turning angles also but other than that everything was good.
The rear was good on my setup but I added a 5mm spacer because I wasn't comfortable with how close the tire and rim were to the stock rear strut.
This is what my setup looked like
