window feature?
Old May 7, 2002 | 07:07 PM
Richard 88's Avatar
window feature?
A wierd thing happened today.
This noon I went to Mcdonales drive through for lunch. After I picked up my stuff, I rolled my window back up, but it stuck in the middle and rolled down a little bit itself. I tried couple of times, but it still didi the same thing. Is it some kind of window feature that I don't know?
Old May 7, 2002 | 07:34 PM
viper's Avatar
Sounds like a problem. Take it to the dealer.
Old May 7, 2002 | 08:01 PM
MarkL's Avatar
2002 C240 6-spd (ret)
I'm pretty sure the windows have "pinch protection" when rolled up in one-touch mode. If something in the window is binding, it might "think" something is caught in the window so it rolls down. If you roll it up by holding the switch, it will probably be fine. Like viper said, have it checked out.
Old May 8, 2002 | 12:55 AM
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
I've been told by the shop foreman, that the windows may need resynchronization so they can close properly. I.e. they should learn what are the proper opened and closed positions, so if something is in the way during closing they can stop and/or back down.
Old May 8, 2002 | 01:09 AM
sdcaclint's Avatar
C230 kompressor C2 C7
i just think your car didn't want you to eat at mcdonalds anymore.
Old May 8, 2002 | 10:26 AM
MarkL's Avatar
If that is Richard's problem, the synchronization instructions are in the owner's manual. If I remember correctly, you simply roll the window down, then hold the button in the up position until it closes and than a few more seconds. It's something like that, but just check the book.
Old May 8, 2002 | 10:39 AM
Fuzzo's Avatar
I've had this problem and it works just fine after you sync it... close your window holding the button and then hold the button in the close (up position) for about 3 seconds. This re-syncs it and it should work fine after that...
i seem to have to do it every coupla months..
Old May 8, 2002 | 11:41 AM
Duffer's Avatar
2002 C230K, 2001 Audi TT 225 Coupe
This seems to happen with all cars with the anti pinch feature - you may want to blow some air down the door to remove any little fuzzy thingies or large lint that may be stuck down there. But the other's advice should reset the computer and work fine afterwards.
Old May 8, 2002 | 03:58 PM
toki999's Avatar
C230 Kompressor Sports Sedan
or maybe car didn't wanna take the smell of burgers and fries....????? things to ponder......hmmmmmmmm
Old May 8, 2002 | 04:06 PM
Richard 88's Avatar
Thanks for all the input
I guess I got the message from my baby about her feeling of Mcdonaldes:p
Old May 8, 2002 | 04:25 PM
SoCal240/6's Avatar
'01 C240/6
These cars seem to unfortunately have a lot of unique electrial "features."
Old May 8, 2002 | 06:49 PM
shtatc's Avatar
2001 C240 6spd
I have yet to have any window problems..but one thing I do check every once in awhile is the feature that:
1. When you hold the open button down (do not just push and release to unlock the door - need to keep button held down), all four windows (sedan) will go down.
2. Hole lock button down, all four windows go up.
That's one thing I do to make sure windows and key are working properly.
That is one feature that the dealer did not tell me about - just happen to hold the open button down and then all the windows started to roll down.
Old May 8, 2002 | 09:52 PM
gab's Avatar
gab
why you traded in your RSX-S for an automatic C230K?
Old May 9, 2002 | 03:25 PM
toki999's Avatar
if u have p.roof
and press lock or unlock and hold, p.roof will open and close
as in same fashion like window.......it's called summer feature.
dave
Old May 9, 2002 | 04:13 PM
revstriker's Avatar
K Car
This will also work on the sunroof. However, I believe it works with an infrared signal, and not the radio signal as the lock and unlock work. You have to be standing close to the car for it to work (in some cases, you have to point your key fob right at the door handle).
Old May 10, 2002 | 01:37 PM
MarkL's Avatar
Also, I believe holding down the remote buttons to open and close the windows/roof doesn't prove the operation of the one-touch function, where the synchronization problem seems to crop up. You have to check that with the individual window switches, or the "all close" function via the recirculate button (discussed before).
Old May 10, 2002 | 05:24 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Re: window feature?
thats funny i had the same problem yesturday, i got worried it would not go up because it was looking pretty cloudy. but lucky after a cupple tries it did. in all my old mercedes the windows always got stuck up or down.
