Intermittent Parking Lamp Blinking
Video of the blinking
https://www.facebook.com/100010269304632/videos/1176719669346999/
Thank you in advance!!
The actual turn signal bulb is above the low beam (upper L corner of the headlight).
First, the obvious stuff.
Is your headlight switch turned to 0 or Automatic, as opposed to Parking lamp mode?
Have you tried switching the bulbs between L and R side?
Has the headlight electrical system or wiring been modified from stock?
In the video, its on Parking lamp mode but same thing happens on Auto or parking lamp or low beam. Doesn't happen at 0.
Didn't try switching bulbs between L and R. I'll try that.
All stock, no modification.
