722.6 p0730 w203. Help.
Old Sep 23, 2020 | 06:28 PM
brad dotson's Avatar
C320 2002
Car was shifting perfect. Never had an issue with it. Went totto drive onewone day and it hasn't shifted out ifiif 2nd since. Trans fluid wicked into tcm which faulted the module. bought a replacement tcm and changed adapter plug and cleaned the harness. Correct fluid level. And I believe the conductor plate is functioning based on values from data stream. Not quite sure where to go from here. I can scan any module and answer any question nessicary for diagnostic assistance.
Old Sep 24, 2020 | 05:09 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
While you had everything opened up, did you take some rags and wipe up a bunch of extra transmission fluid? I found the wires were all still wet, even years after changing out the pilot bushing. Fluid gets into the weirdest places even after an initial cleaning.
Old Sep 24, 2020 | 01:05 PM
tjts1's Avatar
C320
You need an MB specific scan tool that can talk to the TCM directly.
