2006 C280 4-Matic Broken Coil Springs F & R, Need Advise
Old Jan 29, 2021 | 04:40 PM
Foggy200's Avatar
2013 C300 4MATIC, 2006 C-280 W4
Hi Guys,
Have a 2006 C280 4-Matic and recently broke both a Front Driver's Side and Rear Driver's Side Coil Spring.
Having a hard time locating stock or replacement springs, other that some H&R lowering springs from Tire Rack.
1. Would lowering the car 1&1/2" all around be okay?
2. Should I replace F Struts and R Shocks with higher dampened version?
Cheers,
-Foggy200
P.S. 140,000 miles on Odometer
Old Feb 1, 2021 | 09:54 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
If the springs are designed with 4Matic in mind, then there won't be a problem as long as you're okay with the reduced ground clearance. 1.5" isn't bad at all. Just have to watch for curbs and speed bumps.
The optimal setup would be to install dedicated shocks as well, but you can get away with not doing so. The difference is not as big as some people may lead you to think.
Old Feb 1, 2021 | 06:49 PM
acetaylor's Avatar
07 C280 4matic, 2014 GL450, 91 VW Vanagon
Try https://www.pelicanparts.com/. I got a rear spring for my 07 C280 4matic from those folks.
