C320 Oil Level - Correct method of testing
Old Feb 27, 2021 | 12:46 PM
Tchai Quentin's Avatar
C320
We have a C320. We have two conflicting oil test results and dont know the right level.
1. Manual test - following the method in the manual, oil level indicated OK
2. On a YouTube vide, an alternative check - holding the odometer reset button down, we get the following output. Oil level shows “-,- quarts”
Which one would be correct..? No oil warning light has come on yet.
Do we fill up or is the oil level OK per the first response?
Old Mar 3, 2021 | 02:38 AM
jggarcia.vc's Avatar
2005 C230 Kompressor Sedan, 2003 CLK55 AMG, 2021 GLC300
When I perform oil changes I use the Dyno Mode to help determine Oil Level which is the the 2nd one you show.
