Check coolant level often
Old Feb 28, 2021 | 06:41 PM
drho2004's Avatar
2005 C230 SS
Hello, 205 W203 with a126k miles. recently when i drive it for a few days straight i get the 'check coolant' level warning on the dash. i checked under the car and in the engine bay and i dont see any leaks. i fill up with benz approved coolant and keep driving. but its happening almost weekly when i drive it for a few days in a roll. now i didnt noticed this too much since i wasnt driving my car very much because of the pandemic, its mostly in the garage. and if i did drive it it was short 10 min drives to the store. just wondering what could be causing this as i dont see any physical leaks. i searched the forum but found mostly about physical leaks. any help is appreciated!
Old Feb 28, 2021 | 06:51 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Are you sure you do not have a physical leak at the back of the engine?
Leaks often dry up before they drip onto the trays. Checking underneath is not a good indicator. Check the actual engine as there are several plastic pipes known to go bad. See thread above.
Old Mar 1, 2021 | 08:12 PM
drho2004's Avatar
2005 C230 SS
thank you sir! i did look back there and yes there is that leak! thank you for the heads up on it! she an old girl now, shall see if its worth it
Old Mar 1, 2021 | 08:18 PM
slammer111's Avatar
Glad you found the problem.
There are 3 pipes and 1 nipple that are known for cracking and leaking, as mentioned in that thread above. I highly recommend changing out all 4. The old parts all made of the same inferior grade of plastic so another leak will be imminent. All of mine failed within a few months of each other.
MB changed the grade of plastic used for some of the pipes. Your dealer will have this information. For this reason I recommend only buying OEM (Geniune MB, from a dealer or a reputable distributor) pipes, as this is the only way to guarantee you're getting the ones made from the updated plastic.
