Turn Signal Left Mirror Warning on dashboard
Old Mar 31, 2021 | 12:30 PM
laons1308's Avatar
C180 2007
Angry Turn Signal Left Mirror Warning on dashboard
New to posting so apologies if not clear.
Have a 2007 Mercedes C180 W203 which has been having the above intermittent problem. It happend a couple of weeks ago and I looked at all the forums and followed the guidance in removing the mirror and cleaning all the connections etc. Problem went away but it is back permanently. Took the mirror apart but the the main issue seems to be the LED lamp on the door mirror is permanently on. I measured the voltage with a meter and I have 12 volts all the time at the two terminals. Should I have 12 volts all the time or do I have a wiring problem? With the fault light on the dashboard, the front and back indicators work OK but it sounds like double speed on the flasher unit and the door mirror stays on but does not flash. I f I disconnect the LED bulb unit on the door, the fault light still stays on the dashboard and the front and back indicators work but it sounds like double speed on the flasher unit.
Any help folks would be appreciated.
Old Mar 31, 2021 | 12:41 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The double speed flashing in the dash is the car's way of telling you there's something wrong with the blinker system. Usually it refers to a bulb out situation, but this doesn't seem to be the case for you.
The blinker LEDs don't have much circuitry. The actual "blinking" part is controlled by the front SAM.
Try swapping the other mirror LED assembly over and see if the problem goes away. Also try swapping your front and rear signal bulbs too. Process of elimination.
If everything fails, unfortunately it'll be your front SAM.
Old Apr 1, 2021 | 11:55 AM
laons1308's Avatar
C180 2007
Thanks of the feedback. Went to the car today and the problem has gone away. If it happens again I will try your suggestions.
Old Apr 2, 2021 | 03:53 PM
Donald McPherso's Avatar
180 Elegance
My one did that too. Turned out to be the wire inside the plastic sheath had broken. The bit that would bend and stretch as the mirror folds and unfolds. I cut the section out and re-soldered and shrink wrapped a new piece in.
