Front Right Foglight Error, why?
I noticed if I turn the fog lights on before I turn the ignition on no errors come up but really want it to work the proper way
Try changing your headlight setting to Xenon present, see if it would fix the problem.
If you have cut the wires on the fog lights to tap into the starters, ballast, etc, etc... then you may very well be stuck with the error for good.
On the "HID headlights" you mentioned, I am assuming it is NOT the MB "Bi-Xenon" headlamp assembly but instead another aftermarket HID brand. Depending on the type of installation used on your headlamps, you may encounter errors on the headlamps as well (after driving long periods ot time due to the overheating of the wiring associated with the headlamps)
Your problem "could" be fixed, but it could be costly, as you may have to re-run wiring harnessed to correct the problem
Note: Xenon is a registered mark of High Intensity Discharge (HID) lights, currently licensed and used by some German manufacturer brands.
Wiedermann
Again there are no errors on my headlights the topic is on my foglight. Its only that one foglight and nothing what so ever was cut, Ive never heard of an install where you had to cut wires unless it was a rig?
Wires overheating, if the factory ones don't overheat why would these?
