I’m new here and need some help. My C220 CDI is running in limp mode and the OBD has picked up a number of faults that I have worked on and cannot for the life of me understand why the engine light is still on and it’s still running in limp mode.
That was until I discovered some ‘strange’ wiring in the fuse box (picture attached)
When I remove this ‘bypass’ and place the fuse in its correct position the engine will not start! However in its current set up the engine will start but still runs in limp mode and has the engine light on. I cannot find anything mechanically wrong and I have cleaned the EGR and checked the MAF and can’t find anything.
I have had some electrical issues too. The dashboard would reset (but it looks like I may have sorted that) and the sunroof won’t open either.
Hi. I'm new here as well and having sane problem of errors , limp mode and fuse bypass setup like you. Wondering if you got it sorted. Pls share any knowledge you have on this issue. Thanks in advance.
