Identified A Coolant Leak - Heater Hose (A2098300096)
Old May 21, 2021 | 03:29 PM
Menemis's Avatar
2005 C230
Found another coolant LEAK at the back of the engine going to the firewall. If my Google skills are correct, this is showing to be a heater hose - part # A2098300096.
Any DIY's or instructions on how to go about and replacing it?
Not sure what happens once I remove it from the firewall. Also I remember, that hose clip can be tricky to pry open when I replaced the water pipe a while back.
Old May 21, 2021 | 05:48 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I imagine it's just pulling out a metal clip then simply popping it out. But wouldn't know for sure. Buy the new part then you can see how it works.
This hose isn't known for failing (haven't read about anyone else having a leak there), but anything is possible.
Old May 24, 2021 | 09:02 PM
Menemis's Avatar
2005 C230
Waiting on the part to come in.
Didn't see any leaks here when I replaced the water pipe recently. Not sure if removing this pipe from the bracket caused a crack or something.
