Washer problem
Old Jun 5, 2021 | 08:56 AM
Joa1988's Avatar
2005 C200 Kompressor W203
Washer problem
Hi guys hope youre well ,i need some help , my Benz washer motot seems to go on but no water squirts out on the windshield ,there is no water under my car so there is no leaks.
Old Jun 6, 2021 | 03:12 AM
tlg731's Avatar
2002 C230 kompressor coupe M111 2.3l
If the pump is running when you hit the switch your spray nozzels are more than likely plugged. If you have access to an air compressor remove the nozzles from the hood and disconnect the hose running to them and blow air through them in the opposite direction of the flow of washer fluid.
Old Jun 8, 2021 | 01:23 AM
wyneduke's Avatar
M-Class
Are you using MB washer fluid? Aftermarket ones can cause the hose to clog.
Old Jun 8, 2021 | 02:31 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Might just be bad luck. Pop the motor out and inspect and clean. Worst case just replace the motor and grommets.
I can't imagine any aftermarket washer fluid clogging the system unless something else ended up inside the tank.
Old Jun 10, 2021 | 09:50 AM
shan's Avatar
W203 (2007), W120 (1962)
I had a similar problem with one of the nozzles on the driver side. I used a large syringe and forced air through the nozzle in the opposite direction several times until it cleared up. Do be careful not to push the needle too deep into the nozzle.
Old Jul 9, 2021 | 03:17 PM
sined's Avatar
I had the problem, in my case it is the electronic who went out, expensive module, so I run a wire from the fuse box and power the motor
