What's the black thing on the windshield?
Old May 13, 2002 | 04:05 PM
Smoky's Avatar
MB coupe.
There is a big black lump on the inside of the windshield, behind the rear-view mirror. It has a couple of windows on the glass side, open to the front of the car.
What is this thing?
Loving' my car. 351 km.
Smoky
Old May 13, 2002 | 04:07 PM
MarkL's Avatar
2002 C240 6-spd (ret)
I think you're talking about the rain sensor. The small "window" is where it detects the amount of raindrops on the glass.
Old May 13, 2002 | 04:09 PM
Lynn's Avatar
I think the sensor for the automatic headlights is in there, too.
Old May 13, 2002 | 04:10 PM
WebGuyNJ's Avatar
2002 C230K
Any way to slow the Automatic Wipers?
Ok, I have the rain sensor too. And, Well... I wish i didn't now! I think it wipes way to frequently. Is there any way to change the sensitivity?
BrabusCClass's Avatar
GL450, Sienna SE
Its the rain sensor.
Old May 13, 2002 | 04:19 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Re: Any way to slow the Automatic Wipers?
You could turn it off, then push in the stalk every time that you want to wipe the windshield.
I'm sorry, but I don't understand why you'd want to have a windshield with rain on it? I actually think that it's too slow usually.
Old May 13, 2002 | 04:31 PM
MarkL's Avatar
Not sure about that. If you look at the "vent" or "cowl" inset into the hood (where the windshield washers are located), you'll notice a small black dome in the center. I've always thought this was the headlight sensor, but not 100% sure.
Old May 13, 2002 | 05:14 PM
jswedberg's Avatar
C32 AMG
The black marble on the cowl is for the climate control sun sensor.
The top-center windshield stuff is the headlight (and also instrument light) sun sensor and the rain sensor.
Do a search in the forums on the adjusting-rain-wiper-interval thing - I think it is adjustable by the dealer.
Old May 13, 2002 | 06:27 PM
DtS's Avatar
DtS
C200 Kompressor
Keep your windshield clean. Dirt on it can mess up the functionality of the rain sensor, making it go crazy...
Old May 13, 2002 | 07:32 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i think that the speed of the wiper when using the rain sensor is a little bit too fast
just hate the look when the wipers are fast...it is actually quite distracting.
Old May 13, 2002 | 08:38 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
What's the little sensor of the back of the rear view mirror (the side facing the windshield)? It looks like a photocell.
thanks
Jim
Old May 13, 2002 | 09:19 PM
Lynn's Avatar
That is the sensor for the autodimming rear view mirrors.
Old May 13, 2002 | 10:55 PM
Are you sure? I'm not talking about the one that is on the mirror side of the mirror unit that you can see while seated in the car. The sensor I am referring to can only be seen from looking at the back of the mirror unit, from the front of the car.
Jim
Old May 13, 2002 | 11:31 PM
Lynn's Avatar
Jim
Jim, I misunerstood which sensor you meant. After just going out to look at the car, I believe that the the sensor on the back of the mirror is for the automatic headlights. The "eye" in the black housing that I thought was for the headlights, I now think is the infrared transmitter for the garage door opener.
Old May 14, 2002 | 08:21 AM
Hmm? Don't garage doors use RF transmitters? You'd need a line-of-site arrangement for infrared, like your TV at home. I know my stock handheld garage door opener doesn't have any visible sensors/emitters on its casing.
Jim
Old May 14, 2002 | 09:43 AM
mdp c230k's Avatar
2002 c230k
The depression on the back of the mirror housing is the sensor for the dimming feature. There is also a unsilvered spot on the front of the mirror in the upper right that is for the headlights of the car behind you to be sensed by a CDS type cell. If the front sensor thinks its dark out and light hits the mirror it will dim the mirrors progressively with increase light differential between the front and back side of the mirror. Try it by putting your finger over the sensor on the back side of your mirror without blocking the front sensor during the day and the mirror will dim in about 5 seconds.
Old May 14, 2002 | 10:39 AM
MarkL's Avatar
That's exactly right. Two sensors are required for the dimming mirror to compare what's coming toward the car and what's behind it. You can cover the rear one in daytime and the mirror will darken since it thinks the front sensor sees bright headlights. Cover the front one at night and the mirror will lighten... This also controls the driver dimming side mirror.
Old May 14, 2002 | 03:52 PM
WebGuyNJ's Avatar
2002 C230K
Re: Re: Any way to slow the Automatic Wipers?
Guess I've been spoiled by RainEx and intermittent wipers for too long... Not ready for this Luxuuury rain sensor thingie
Old May 14, 2002 | 09:22 PM
Geoff's Avatar
Minor rant...
I really wish the automatic wipers would check if the drivers side door is open before kicking on. A couple times in the winter I turned the car on with snow on the windshield and was thanked with a pile of snow on my left leg and the inside of the door. I've since learned by lesson, but it would be nice if the logic was there to check that.
