W203 C200 slow acceleration in low rev.
Old Jun 27, 2021 | 11:40 AM
Chupaxl's Avatar
C220 W205
Hello everyone. So I'm having a first generation W203 C200, the car is nice when driving overall, but it's been like 3 months, I'm feeling like the engine is having a bad time going up revs, until 2500-3000 rpm.
For example, going on a 2nd gear at low revs, and using all of the accelerator wouldn't make an acceleration until I pass the 2500-3000 rpm bar, and then, the car is gaining all it's power.
Plus, the car is sometimes putting itself in secure mode (not going up the 3000 rpm) and that's random, I have to manually turn off the engine and turn it back on to reset that locking.
Anyone has some ideas about what can make the problem ? DIAG didn't do anything in either secure mode or not secure.
Thank you everyone in advance !
Old Jun 27, 2021 | 09:40 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
If the C200 is supercharged, check the hoses that bring air to the super charger and make sure that nothing has come loose.
Old Jun 28, 2021 | 02:46 AM
Chupaxl's Avatar
C220 W205
Hello. Thanks for your reply.
i forgot to mention, the C200 is a diesel one.
Old Jun 28, 2021 | 03:41 AM
rnd_ash's Avatar
2003 E55 AMG
I have this exact same issue. Ive managed to trace it down to a bad software version MB uses. I decided to update my ECU software a while back from 2006 to 2008, and ever since then it kinda accelerates until hitting 3000rpm and then it really accelerates.
Looking at the boost pressure via OBD, it appears the engine seems to apply boost in an almost binary manner (off/on) rather than gradually increasing it as the revs increase.
​​​​​ive confirmed this is definatly software as the turbos actuator works perfectly fine (tested in DAS).
