Cooling system/air conditioner
Anyone have any ideas?
Bob C
Perkasie, PA
I believe the normal coolant operating temperature is around 90 something.When you turn the AC on, the big *** radiator fan switches on. Seems like the car senses that the AC -> radiator fan on -> coolant temp drop are related, and turns off the AC to get back to operating temp... ?!
Plain water has a higher specific heat capacity than coolant mix, but you tried with essentially 3 different "mixes", so that's not it.
Maybe the AC is low on refrigerant, so the condenser does not heat up as much as it's "supposed to".
