DIY - setting up the AUX input for iPod, mp3 player, etc.
Rating: Thread Rating: 23 votes, 4.65 average.
Old 01-04-2007, 11:12 AM
  #351
YoYiTo's Avatar
'02 MB C240 6spd / '92 BMW 325i 5spd
nevermind it doesnt work for my car
Old 01-04-2007, 11:21 AM
  #352
wizkid's Avatar
Ford Pinto
I feel your pain. Us 2002 owners and you 01 guys, got the shaft on this.
Old 01-04-2007, 12:06 PM
  #353
Blake P's Avatar
'09 A4 S Line
I have an ipod kit installed in my '04. It acts as the cd changer so you can't have both the changer and ipod, but luckily my car didn't come with a changer!
Old 01-04-2007, 01:05 PM
  #354
YoYiTo's Avatar
i dont want to lose my cd changer
i guess i'll get this Harman Kardon Drive + Play its $99.95 at Crutchfield.
Old 01-04-2007, 01:08 PM
  #355
Blake P's Avatar
'09 A4 S Line
FM transmitter?
Old 01-04-2007, 01:38 PM
  #356
RES
RES's Avatar
2005 C55, 1988 260E, 2000 Chevrolet Silverado
You can add the Euro command and TV tuner with the wiring harness and that will give you both changer and Aux input. Not so cheap though And it gives you two more inputs with video to connect your video I-pod for watching movies and a PS2 for games while driving no I'm not that dumb!
Old 01-04-2007, 01:41 PM
  #357
YoYiTo's Avatar
FM transmitter?
i called my local shop and they said it ads an aux to your stock radio. im going there friday and ill give you the complete details
i would go with the euro comand route but im not sure if i'll keep the car that long.
Old 01-04-2007, 04:14 PM
  #358
YoYiTo's Avatar
i just thought of this: is there a way that i can disable my cd changer and plugin the ipod? if so, i can create a y-jack or a switch and connect the cd changer and the ipod. whenever i dont want to use the cds i'll just remove the magazine.
would my idea work?
Old 01-16-2007, 06:39 AM
  #359
Yonosai's Avatar
C-Class (S204 - 2011 facelift)
Hi,
Does anyone ca give us the schema of this cable?
I think it's pretty simple and I want to plug a cable with a male connection (to avoid multiple cable connection losses)
Old 01-17-2007, 12:35 AM
  #360
EUROtimon's Avatar
c240
installed it today...took me about 3 min after i got the screw driver. its just click and go simple and easy.
Old 01-17-2007, 06:15 AM
  #361
Yonosai's Avatar
Hi,
Does anyone can give us the electric schema of this cable?
I'd like to make my own to have a male jack (to connect directly to the ipod)
thanks
Old 01-18-2007, 12:58 PM
  #362
polarbexar's Avatar
2017 CLA Motorsport Edition, 2015 G550, 2012 GLK350
can we sticky this with the other DIY stuff?
Old 01-19-2007, 04:03 PM
  #363
Bgeeza's Avatar
2001 c230K coupe
Does anyone know if the 2001 230K coupe comes pre-wired for the AUX connector in the UK? i had a look under the door seal but couldnt see it.
Old 01-23-2007, 11:36 AM
  #364
TSC2's Avatar
C200 CDI Elegance Sport Edition (Euro)
Hi, not sure why but I can't see the pics.. :-( is that happening to you all as well ? I was much interested in understanding how you did it. Thanks !
Old 01-23-2007, 05:07 PM
  #365
aussiechick28's Avatar
2007, C280
My husband and I tried to do this on our cars. He drives an 06 C350 SS, and I drive an 07 C280 luxury.
With his car, everything was fine, exactly as in the pictures and instructed here.
With my car, it looks like the pre-wired cable was being used for something else. There was no connector free. When comparing the two cars, we determined that I do have the cable, but it is connected to something towards the back of the car as the cable went back behind the passenger seat.
I do have the harmon/kardon entertainment package and Sirius Satellite Radio.
Do you think my pre-wired cable is being used for something to do with the Sirius?
Any advice would be greatly appreciated!
Thanks!
Old 01-24-2007, 04:12 AM
  #366
Yonosai's Avatar
And if anyone had a trick to allow proper contacts (and avoiding shortcut risks).
Old 01-24-2007, 04:23 AM
  #367
Yonosai's Avatar
Originally Posted by d2daniel
Share my ipod nano and Belkin car kit.
Nothing changing outward appearance.
Strongly suggest using Belkin car kit into ur car,it can auto turn off ipod when engine stop.
What's the reference of this belkin kit?
I found one but is for an iPod with Dock Connector (ref : F8V7058eaAPLBLK)
What's yours?
Old 01-24-2007, 07:37 AM
  #368
d2daniel's Avatar
The same~~~
http://catalog.belkin.com/IWCatProdu...duct_Id=256425
Old 01-27-2007, 12:20 PM
  #369
Jkw
Jkw's Avatar
2004.5 C 230
I have a '04 so I don't have the aux in.
I wouldn't mind losing use of my changer for the iPod.
What did you use to do this?
Does the head unit work as before, but just think the iPod is the Changer?
Thanks in Advance,
Jkw
Old 01-27-2007, 12:40 PM
  #370
RES
RES's Avatar
Thanks in Advance,
Jkw
If yours is 2004.5, Did you check for the plug on the right side under the trim piece? I just added nav and new harness for tv tuner and it has aux in.
Old 01-27-2007, 01:31 PM
  #371
Jkw
Jkw's Avatar
2004.5 C 230
Yea, Mine is a '04.5 Didn't think that would matter as I had the old radio, I guess I'll have to pull the car apart to find out.
Thanks for the advise.
By the way your car looks hot, love white
Jkw
Old 01-27-2007, 01:40 PM
  #372
RES
RES's Avatar
Jkw
Search there is something different on some that will allow you a Aux in? Mine didn't have it. The trim comes out prtty easy. there is a little cover over the right side kick panel with a screw under it. then you just pull up on the threshhold look for black plug. But if your radio does not have aux in it most likely wont work
Old 01-27-2007, 02:56 PM
  #373
Blake P's Avatar
'09 A4 S Line
Even if he did have a mystery AUX-in, how what button on the head unit would activate it?
Jkw: I had a Soundgate iPod kit installed, which acts as the cd changer and the head unit works exactly as before. Here's what I got:
http://www.logjamelectronics.com/soundauxmb1.html
and...
http://www.logjamelectronics.com/pieunipod.html
It doesn't do anything fancy like show song titles on the display or have the ability to control the ipod through the head unit, but it charges and plays the ipod wonderfully.
Old 01-29-2007, 09:19 AM
  #374
Jkw
Jkw's Avatar
2004.5 C 230
and...
Thanks for the info,
I guess that's the best I can hope for unless I change the head unit.
Do you happen to know of one that works and also looks good w/ Mercades "Organge" interior lighting?
Old 01-29-2007, 12:24 PM
  #375
Blake P's Avatar
'09 A4 S Line
Have you seen the new Pioneer nav (AVIC-D3, I think?) that allows you to customize the display color to match your factory interior?
You have already rated this thread Rating: Thread Rating: 23 votes, 4.65 average.
Quick Reply: DIY - setting up the AUX input for iPod, mp3 player, etc.
