Thermostat Recommendations
Fast forward to now... Mostly working from home so the car has been sitting a lot, but when needed it sure is cold again! Even worse than last time around - takes the engine forever to reach temp. So, I'm guessing that the thermostat is a dud again after too short of a lifespan.
I can't recall the brand I used unfortunately. Are there thermostats that anyone has had particularly good or bad luck with? I'd like to put one in and be done with it for a reasonable amount of time.
Thanks!
KP
These thermostats do die every few years. They are designed to fail open so that people don't overheat their engines. Personally I'm on my 3rd one.
Lastly, be sure to replace all the plastic coolant pipes, including the one that holds the thermostat. I'm guessing the seal failed because the plastic has turned to powder. These have all been updated with a different grade of plastic. The original parts are all known to fail.
And about the plastic cooling system parts... They most definitely have a very specific lifespan! I've replaced most of them, minus the long pipe thingy that runs up near the valve cover. I have a new one of those on the shelf and ready to go - probably a good exercise to get it done at the same time as the thermostat. I replaced the water outlet that holds the thermostat in place last time around, hopefully it's still good. The OEM one was still installed back then, and I recall extracting the broken portion(s) out of the block...
Lastly, I would keep a spare nipple around. The thing can break for no reason. I remember mine broke when I placed my hand on the overflow pipe (connecting the pipe you described and the coolant tank) while doing an unrelated repair. PN is also in the thread I posted. Also if you haven't done so, look into replacing the coolant tank. The black plastic on top also turns to powder over time. I remember I could break pieces off the old tank like a cookie. The lid and all hoses and clamps can be reused.
