poor idle?
Old Feb 15, 2022 | 10:44 AM
MrFin's Avatar
c class 180 kompressor,03,w203 m271
poor idle?
Hello, i have a problem with my c180 komp. Idle runs pretty unstable. I had this error code when i scanned it. i changed the camshsft magnet,code dissapeared and never came back. it used to run bit ruff but after i changed the magnet the idle is unstable.i put video so you can see
https://youtu.be/kD8v66yvkPo
Car Scanner ELM OBD2
DTC report
============6==============
P0010
Raw code: 0010
ECU: 01
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
thanks in advance
Old Feb 15, 2022 | 10:10 PM
jggarcia.vc's Avatar
2005 C230 Kompressor Sedan, 2003 CLK55 AMG, 2021 GLC300
check timing chain, chain tensioner, actuators and guides could also be your Camshaft Sensor located by the exhaust manifold if you already replaced the magnets..
GL
