W203 brakes problem
Old Mar 13, 2022 | 05:20 PM
hrosik's Avatar
C-class w203 220CDI 150hp
W203 brakes problem
Hey guys, I would like to ask for help with my car - C-class W203 2004 150hp, please.
The problem is hard brakes, but in some weird way. The brake pedal is hard only when pressed very quickly and strongly, then the brakes are almost not working. But when I press the pedal slowly or normally(not extremely quickly), the breaks are working perfectly, even when I increase the breaking power, still no problem, it can even activate the ABS on dry road. Therefore I believe that the booster is not dead.
I have new brake fluid + flush and bleed, new hoses, rotors and pads are OK, calipers cleaned and lubed.
Any ideas what could cause this symptom?
Thanks for any tip
