Android Head unit no sound, need help
The link for the unit: https://www.ebay.com/itm/39390009862...Cclp%3A2563228
The wiring for the new unit:
Wiring for the original unit:
Unfortunately, I have seen mixed reviews regarding the quality of inexpensive units like the one you bought. You may need to exchange and hope that the replacement does not have the same problem.
If that is correct, the most likely problems are either (1) the unit is defective or (2) the speakers are wired incorrectly. Is there any way for you to bench test the unit? To do this, you would need a 12-volt power source (I use an old computer power supply) and at least one speaker.
There are several videos like this available.
I have the exact head unit as yourself and purchased it from ebay to install in my Mitsubishi outlander 2010. I was having the same problem as you, everything works perfectly except there is no sound. I searched for hours and finally found an answer on YouTube. Basically the amp in the car needs power and the harnesses that come with the head unit do not provide that so what I did was connect the blue/green wire from the head unit that has a label on it saying amp cntrl into the red power cable in the original harness and voilaa the sound came on.
Sorry for my lack of knowledge I am an amateur but below is the link to the YouTube video.
Hope this helps!
https://youtu.be/_6PtZj1zQk8
Hope this helps!
Thank you very much for your reply and the video. I am not sure the problem I am having is due to the same cause you had. Because there is a wire saying amp control from the head unit, and also a wire saying amp control from the harness. I was told to connect them together to provide power for the amp. I measured the voltage between the two wires. It did have 12 V between them.
Thanks!
I think your instructions may be based on a right-hand drive car. I have not seen a CAN Bus block on the passenger side of my (left-hand drive) car. There is one in the panel beneath the steering wheel. As shown in the link, I made a connection to the CAN Bus block when I retrofitted memory seats in my car. You need to remove a few torx fasteners from the panel directly beneath the steering wheel and the block should be obvious. It will have several brown and brown/red striped wires attached to it.
Good luck.
Good luck.
Thanks for the information. I see in the W211 video in thread at post#14 there is a CAN bus above the glove compartment. I will check on my C55. The eBay seller instructed to connect to passenger side. The CAN bus block under the steering wheel has a connector in location 8 already.
Good luck.
