CLC180K wing mirror
Firstly I do not know if I am in the right forum as the CLC/CL203 does not appear in the forum lists, also hard to find on internet.
My problem is some nice guy/girl decided to see if my wing mirror could take a knock, No! the indicator got shattered. I have looked all over the net for wing mirror cover removal, I have found
every wing mirror you could imagine but not the CLC. I have removed the glass and the 4 x tore 10 screws that hold the adjustment driver
but still cannot remove cover. any assistance would be greatly appreciated, I thought this would be an easy exercise after changing out the engine wiring loom, however it seems elusive.
Thank you in advance
The CLC is technically a W203, so you are in the right place. However these cars are extremely rare. I don't think I've seen another CLC in this forum.
Not sure if your mirrors are the power folding model but the covers should be available separately. The blinker I'm pretty sure is available separately as well. Mind you I'm basing this answer on the previous version (ie non CLC) C.
it is advice on how to remove the cover its self that I require.
I have and have had several different MB models and have managed to remove the wing mirror covers on them
However this one is being a pain.
If all else fails, a rotary (Dremel) tool with a cutting blade is your best friend.
