2007 c230, noise and jerk when shifting gears
Old Jun 2, 2022 | 10:28 AM
EvelinaGukasyan's Avatar
C230
Sorry if I’m posting this in the wrong section, just made an account on here.
I own a 2007 c230 and whenever I shift gears, there’s a strange grinding sound in the rear right corner of the car as it sounds like from the drivers seat. The car also moves a little. Hasn’t happened before, new problem .
Any suggestions? Could it be transmission fluid or breaks? I know some of you will tell me to go to get it checked out but I want to see if anyone had the same issue
Old Jun 3, 2022 | 03:24 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Is your car automatic or manual? What's the mileage?
It wouldn't hurt to change your fluid and filter (automatic) if it's never been done. Official service interval is 60k km but you can probably get away with less than that.
Have you inspected the rubber flex discs (guibos)? There are 2. One is between the transmission and drive shaft, and the other is between the drive shaft and rear differential.
