Installing new grille. Can you help?
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
I just received the sport grille (large three-pointed star mounts in the middle of it) for my C240 from performanceproducts.com. It came with a small tube of something (glue?) and a T shaped tool, but no instructions. What are these used for?
thanks
Jim
thanks
Jim
1 Post
My wife called them. First call the guy said he didn't know what it was for. Second call he said it was glue and some people use it for added strength to hold the star on. He said the T shaped thing was some sort of tension device to hold the star on too, but didn't know how to use it. Performanceproducts.com get an "F" for customer service
The grill itself went on very easily. I used the "glue" to hold the star on. I'll hold onto the T shaped thing until I find out what it is really for. Thanks.
Jim
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Jim
Re: Installing new grille. Can you help?
thanks
Jim
thanks
Jim
Then, open you hood, under the neath of the original grille, you should see some screws around it, unscrew them, you should be ready to go.
1 Post
The "T" is a tool that is use to sqeezes the black glue out of the tube (believe it or not). I guess they want you to use up all the glue.
I just squeezed out a thin bead around the back of the star before I mounted it on the grille. It seemed to work out okay. For some reason the left and right sides of the ring on the star stick out slightly. The will NOT lay flat no matter how much pressure I exert. I wonder if super glue would work on the plastics in the grille and star?
On a related note, I also got the flat hood star. No directions came with it, of course! I THINK I put it on correctly. Anyone care to tell me if you are supposed to put the rubber coated bar with its tips facing up or down?
Jim
