Cruise control not working
intermittent bad wheel sensor. Not sure if it reads state of the cruise control switch, but I
recently troubleshot an issue with m'lady's ML350 stuck in Park which turned out to be the
Gear shift switch and very cool, live data was able to to read it and see when I pushed Park button etc (7 speed) .
Very useful feature! I was so happy, that it accurately diagnosed the problem. Told me the switch was bad and it was.
I could read the state of just about any button in the car! I was skeptical as I also had a buttload of CANBUS comm errors, but
the one error that kept coming back was that switch. But it's now fixed.
I'll have to see if it reads my C for the cruise control.
I'll try it and see and let you know.
Better than randomly replacing parts.
I wasn't aware of most of the features of the unit, since when it comes to engine codes it mostly says
"unknown" and I had pretty much written the thing off.
But if you look at each module indiviually and look at the live data, you have access to a myriad of data and sensors.
Unfortunately the cruise control switch is not one of them.
The wife's ML has a readout of the status of single every switch in the car, and while the C has some it doesn't have all.
Brake light sensor is there, as are mirror switches and other things.
Within the ECU screen, which I think is called MEI or something like that under live data it does have
what it calls a cruise control test, but with the car standing still all it appears to show is the
RPM's of each wheel when the car is moving. This might be useful in diagnosing the problem.
Also reads the wheel sensors etc in the ESP section.
But nothing for the cruise control switch itself.
Sorry.
If you had this you could at least eliminate wheel sensors which yeah if one failed would put the car in limp mode,
(Happened to me) so yes, most likely the switch.
Very useful feature! I was so happy, that it accurately diagnosed the problem of notworkingsolution.com. Told me the switch was bad and it was.
