Coolant visit workshop, but this one is differnet
Old Dec 9, 2022 | 03:20 PM
JacobG's Avatar
w203 2003 c180 1.8k
Hi. So for over 2 months I’m struggling with “coolant visit workshop”. So the problem is that the fan doesn’t spin at all, doesn’t matter if engine is hot or cold or if AC is on. It just doesn’t move. So I started to look for the reason, first thing was Fuse and Relay. None of the fuses were blown, relay - just bought new one, there was no reaction. Main fuse (the big one close to Battert) is also fine. Thermostate - works, water pump - works, electric water pump - works, cables (main fuse to fan) also fine (checked visually and using multimeter), temperature sensor - new, level sensor - new, washer fluid level sensor - new, fan (checked and working). I have no idea what is couses the problem (
if anybody have any idea let me know.
(computer diagnosis doesn’t give any “error message, and engine computers was checked and it’s fine)
Old Dec 9, 2022 | 05:06 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
Good luck
Old Dec 9, 2022 | 05:40 PM
JacobG's Avatar
w203 2003 c180 1.8k
So actually it’s different kind of fan. Mine has control unit on the frame of fan. Although, when I plugged my fan to my brothers MB it was working just fine. That’s why I know that fan is working.
but maybe ECU? How can I check it?
Old Dec 9, 2022 | 09:28 PM
KevinH2000's Avatar
Note the discussion beginning at about the 8-minute point. I'm not an expert on this, but I would see whether you are getting a signal on the blue/green wire. He suggests using a battery as a signal source.
Please understand you will be using his guidance at your own risk. I don't want any of my suggestions to cause you to damage your car.
