Power steering pump overheating! HELP!
could someone help me find the cause of the power steering system, because the power steering pump overheats very much (the oil evaporates, the tank began to pour out, so it either broke or something with the o-ring). It started with the fact that after a few drifts, the pump began to hiss and began to pour out slightly (you could feel it when the oil was heating up). After some time, the pump was completely dead, I barely got home, every now and then I had to add oil. I replaced the pump with a replacement SKV, which is heating up very much, the power steering works better sometimes worse, at low speeds you can hear the sound as if it was frictioning. I calledto mechanic and he said it was probably a factory defect and that I should send it back for complaints. I also showed it to the mechanic, he said it was rather the pump. The oil was changed. Maybe it needs to be flushed somehow? I took off the pump again and will send it tomorrow for this complaint, but I'm afraid that this is not the fault of this pump, but something else is happening with this system. Have any of you had similar situations or have any idea what could be the reason? I care about time because I've been repairing this car for almost a month, and there are no results, so I'm looking for what can cause such a defect. Thanks in advance for your help!
Mercedes-benz w203 1.8K 2005
The fluid should constantly be circulating, when the steering wheel is steady and turning. Not sure how to test that without making a huge mess though.
YOU can sense this when you do a full turn and hit the end you get a little squeal sound which is the relief valve venting the pump flow at pressure back to its little tank.
Some where the oil is going from a high pressure to low pressure without performing work.
Feel around for the hottest PS part and 98% sure the fault lies within.
My guess is the valve if it gets hot without turning.
