C240 2002 Fuse#53 Location?
This is a good source.
It should be in the front SAM which is under the hood near the firewall on the driver's side. Unless it is missing from your car, you will need to remove a plastic drip shield and then open the cover of the SAM before you can access the fuse.
Good luck.
Good luck.
