"All" disconnected, Battery still drains
I need advice on a draining battery 2006 C180 Compressor, Estate, left hand drive (Sweden)
There is a 0.3A leakage that Im struggling to locate.
I have looked at different threads here, but not found something that can help.
I have:
What component further down this cable could be eating the power, where do the two cables end up?
I have:
- Removed all fuses and relays in the fuse boxes rear, cockpit and engine compartment.
- Disconnected all cables from the large connection box next to the battery the one connected straight to positive terminal.
- Disconnected the two large data connectors next to the air filter box.
- Disconnected the alternator main power cable and the smaller connector to the regulator. I read in some post that on rare occasions, the diodes could be faulty and leak power no such luck.
