C180K, C200K conversion to C230K with M271 series 240, 246, 248
After many hours of sifting through the data and checking 6 VINS against each other I can suggest the following findings about the M271.
* If the engine is 2005 spec then it will be specially upgraded already with low noise parts that were recently introduced.
* In all M271 2005 the 5 speed transmission is identical
* In all M271 the crankcase and 5 speed auto slip ring are identical
* all results exclude CGI and SLK for now.
DOES NOT APPLY TO CGI
[series 240, 246, 248 only]
C180K, C200K and C230K differ in the following ways
- piston
- supercharger (only 2 models - one for 230K and one for others.
- ECU (engine control unit)
- Some differences in intercooler and hoses are possible with year of build.
= 140Kw in total without pulley mods
RESULT
In some cases that means 20-40Kw improvement.
CAVEAT
This mod uses only MB parts and should only be done with informed risk and has no implied warranty.
- piston
RESULT
CAVEAT
