Turn signal, long headlights and wipers start and can’t be stopped
Old Aug 23, 2023 | 01:21 PM
V.K's Avatar
V.K
C200
Hi, I own C200 - 2001, I have a rare problem. When I turn on the car, the wipers, the long headlights and the turn signal start working, however I can’t stop them!!! Sometimes the car even couldn’t be turned on! The problem is not the modules( both are changed ), also it’s not the key(and the key hoe), and it’s not the lever which turns on everything of these. All these components are checked, but no mechanic knows from where the problem comes. If you had a similar or the same problem please hit me up.
Old Aug 24, 2023 | 11:37 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Sounds like some sort of short inside your wiper stalk. That is the 1 thing in common.
Did you actually disassemble the stalk to inspect the circuitry?
The turn signal stalk assemblies do wear out anyways. If I were to throw a part at the car, that would be my first guess.
Old Aug 24, 2023 | 11:56 PM
V.K's Avatar
V.K
C200
Yes, we did, it’s not that!
Old Aug 25, 2023 | 07:54 AM
slammer111's Avatar
The thing is that you've already replaced the front SAM (I assume that's what you mean by the module).
Any rodent problems in your area?
Old Aug 25, 2023 | 08:19 AM
V.K's Avatar
V.K
C200
Nope
Old Sep 13, 2023 | 06:48 AM
by_said's Avatar
C32 AMG
Seems like you have a problem with Wiper Stalk Indicator A0005452310
Old Sep 13, 2023 | 04:28 PM
slammer111's Avatar
Honestly I would also consider replacing the wiper stalk assembly.
This is also a good time to change the stalk style if desired. MY2002 is different from MY2003-2004 (nicer rounded plastic ends, but identical electrically and swappable). Can't speak for the ones above.
