M.O.T
Old Oct 5, 2023 | 01:48 PM
littleun's Avatar
c200 w203 classic
M.O.T
Only had the car a couple of months and have my M.O.T coming up soon, I have a problem with the SRS light staying on and message of I malfunction, would it fail because of this, many thanks.
Old Oct 10, 2023 | 10:56 PM
hudsongt500's Avatar
2005 C230 Sedan 1.8K
Not sure if SRS issue will cause you to fail inspection but I think there are two fuses for the system in the under hood fuse box (#45 & 49?). Check fuses first, and if they are good then you will likely need proper scan tool to pinpoint what is causing the SRS issue (module, seat, airbag, etc.). Best of luck.
Old Oct 11, 2023 | 02:20 PM
littleun's Avatar
c200 w203 classic
Thanks for reply Hudson, checked fuses all ok, have a carsoft c520 scanner but it is not showing any fault codes (except glow plugs 3 and 4 faulty changing next week), order a seat belt buckle to try that if its not at least i got a spare
Old Oct 14, 2023 | 02:20 PM
littleun's Avatar
c200 w203 classic
Talking
WOOHOO all sorted, fitted new drivers belt buckle started car and no light,
Old Oct 17, 2023 | 08:28 AM
LarryBender's Avatar
2012 Audi Q7
Congrats. hehe
Old Oct 21, 2023 | 05:03 PM
littleun's Avatar
c200 w203 classic
And it passed
