Knocking sound from front wheels
Old Nov 25, 2023 | 09:32 PM
Rauuul's Avatar
C270 w203
Hello! I have a problem with my w203, a 2002 c270 sedan. I have a knocking sound in the front on rough roads. I have changed almost everything that can be changed underneath the car, even the steering rack and steering rack mounts. One shock absorber has not been changed because the mechanic said it was in good shape and the bearings. The sound seems to come from the steering rack even though I mounted a steering rack rebuilt in a good shop. Source of sound seems to come from that part of the steering rack that connects it to the steering wheel. Any advices/solutions?
Sorry for the poor English I have, I hope you understand what I am saying
Old Nov 25, 2023 | 11:17 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Hard to diagnose through an online forum. Have you checked the sway bar bushings and end links?
Old Nov 26, 2023 | 11:27 AM
Rauuul's Avatar
C270 w203
Sway bar bushing had been changed aswel, still have the problem
Old Nov 26, 2023 | 01:23 PM
slammer111's Avatar
How about the sway bar end links? 2 ball joints per side.
Any competent mechanic should be able to use a pry bar and find any loose components. There are only so many in a car.
Old Nov 26, 2023 | 01:37 PM
Rauuul's Avatar
C270 w203
As I said almost everything is new except for a shock absorber and both bearings. Both sway bar links are new, I bought them from a good brand, so the problem is not there. I will try to upload a video with the sound tonight or tomorrow morning
Old Nov 26, 2023 | 05:07 PM
Rauuul's Avatar
C270 w203
I forgot to mention tough, the noise seems to disappear when is raining, so when the car gets wet and also the sound is very very similar to the knocking of sway bar end links.
Also the car slightly pulls to the right side when i leave the steering wheel free on any speed. On the right side is the shock absorber I changed like one year ago, also good brand and pretty expensive
Old Nov 26, 2023 | 05:13 PM
tkid's Avatar
C230K M271 CL203 2003 model
I had a brand new end link that started knocking after installation!
Must have been the torque setting, after i tightened it, it was OK after that..
I found lifting the front of the car, then using a lever to rock each wheel/tyre up and down, can help isolate the noise?..
It can be hard to pinpoint with the engine running, so being able to create the noise with the engine off is a great way to isolate the source..
