Will the old school AMG rims fit on my 03 station wagon?
Old Dec 12, 2023 | 06:38 PM
benzobenz's Avatar
c320 4 matic station wagon
Hey everyone!
first time Benz owner
stole me a super duper clean garaged 03 station wagon
recently tinted it
now I wanna see if I can fit the old school AMG rims on my white wagon (see attached picture)
not in a rush. I really wanna dial it in proper.
thinking possibly putting it on air bags for a smoother ride… might as well with going with a bigger rim.
and this is a reach… but would it look cleaner if I went wide body with it as well?
my rim budget is 3k
air bags should run me 1k-1.5k
Hopefully I can keep it under 5!
any help and guidance is much appreciated!!!!
Old Dec 14, 2023 | 03:48 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Unlikely to be honest. To know the answer for sure, you'd need to know the offsets of the rims. Those are not real AMG wheels, so there's a good chance they won't be a direct swap.
Old Dec 14, 2023 | 01:45 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
AGREED! Wheel offset is the most important thing to know when changing wheels. Take one of your wheels of and see what the offset is, marked as "ET" with a number.
Here you can check what your car is equipped with:
🚗 Mercedes C-class (w203) 2001 - 2007 ➞ Tire & Wheel Sizes, PCD, Offset, Rims specs ⭐ (cartiresize.net)
Mercedes-Benz C-Class - wheel size, tire size, lug bolt pattern, offset specs. (tirewheelguide.com)
This website is very helpful determining what size wheel and offset you should be able to mount with enough clearance. Helped me quite a bit in the past: Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
You wagon would look super cool with the wheel you are showing if you can make them fit.
Good luck, keep us posted.
