722.6 Still Jerky after oil change
Old Dec 30, 2023 | 10:32 PM
jggarcia.vc's Avatar
2005 C230 Kompressor Sedan, 2003 CLK55 AMG, 2021 GLC300
Just as the title suggest my 2005 C230 with 200k miles started jerking at shifts. At first it was jerky from 1-2 pretty bad. Did an oil change, filter and conductor when i had the valve body out I tested the solenoids they all tested between 3 - 6ohms the TCC solenoid tested the lowest ( 2.8-3.5 ohms I don't recall exactly) and when actuated was the quietest so now Im thinking I should've replaced the TCC solenoid when I had it dropped...
After adaptation reset and drove the car it drove better but shifts where still jerky not as harsh but still there.
Now it's jerky when downshifting as well.
This is all when car is warm and been driving for around for at least 15 minutes.
I am thinking of replacing the TCC solenoid, Sonnax Master Overlap Kit and another fluid change. Or is it my torque converter that's failing? Any input is greatly appreciated no codes when I scanned with Xentry.
