C200K engine noise ??
Old Nov 12, 2004 | 06:41 AM
Ben'sCLK's Avatar
CLK 200 KOMPRESSOR Elegance
I know this is a forum for C-Class owners but I am in Europe and we also have the CLK with the M271 Kompressor engine so the guys here on the CLK forum wont get my problem !
The "tone" of the motor has changed over the last month or so. It has become more "buzzy" and drones a bit more than usual. there aren't any fault codes and the performance is fine !
Does anyone know of any problems with these 1.8K engines, mine is a 2003 cars BTW !
Any help or suggestions would be appreciated greatly !
Old Nov 12, 2004 | 07:02 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
I would check the supercharger - this is the noisiest part of the engine. Also, check the exhaust for leaks.
Old Nov 12, 2004 | 09:13 AM
Ben'sCLK's Avatar
Exhaust doesn't seem to have any leaks !
How would I check the Supercharger ??
Old Nov 13, 2004 | 01:30 AM
vadim's Avatar
I am afraid you have to take it to a dealer. There have been a few reports in this forum of S/C going bad. On the other hand, I am not sure if the dealer will accept your "subjective" opinion as a reason to take any action. Tough one. If you could prove that your engine produces less power than the manufacturer specifies, that would be a different matter - but it is quite difficult to prove.
Old Nov 13, 2004 | 08:06 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
wouldn't a dyno test be able to prove that. i mean there has got to be a set number from the factory of RWHP. so if you had your car dyno'd then you will be able to find out how much yours is producing. still the fact that the dealer may not take action is likely.
Old Nov 14, 2004 | 03:14 AM
vadim's Avatar
They do not specify RWHP output, only crank HP which can not be measured directly on a dyno, so it still would be up to you to prove a power loss fact to a dealer. If you could provide dyno graphs "before" and "after" for your vehicle, that certainly would be a totally different thing.
Old Nov 14, 2004 | 02:22 PM
05Css's Avatar
Well, I can tell you that super chargers are not quite things. Now 2 things could have taken place. With time the super charger got noiser or second is that the super charger is getting bad. Either way I would take it to a dealership and get it check out. Let us know what happend. Thanks
Old Nov 22, 2004 | 11:07 AM
Ben'sCLK's Avatar
Booked in with dealer for next week !
I'll update asap !
