Keyless Go
Old Nov 12, 2004 | 05:39 PM
2k5C230's Avatar
Keyless Go
Anyone know if you can get this as an addon or any aftermarket people make it for a w203??
Old Nov 12, 2004 | 05:43 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Please search as this has been discussed previously.
Old Nov 12, 2004 | 09:26 PM
SUNILP's Avatar
2015 E250D
if you are ready to spend about 3 grand, I am ready to test everything.
Old Nov 12, 2004 | 11:05 PM
Outland's Avatar
2002 C230 Coupe(M111)
You know, if you take the time to write STFF, a simple yes or no would be nice.
Old Nov 13, 2004 | 05:43 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
hmmm, could this be done on a coupe with a manual trans, or do i need automatic?
Old Nov 13, 2004 | 08:28 PM
miroj's Avatar
I havent seen Keyless Go on a manual transmission. I cant see how that would work given that the chance of pressing "OFF" are not trivial. So i would say not likely.
By the same token, it can be done but the car would be much more like a W209 than a W203. The main components that pose the most problems are the gear shift, the ignition switch and the door locks.
If you can get those items running then the rest isnt that hard. The keyless go system is in fact an isolated system which runs its own network.
That is however the EASY part. The changes to FDOK and your vehicle records are critical for your new GREEN KEY which will activate the new ignition switch from scratch. Then you can order the keyless go key fobs with a valid request from Germany whilst you continue to use the conventional keys.
From a hardware point of view there is no real limitation, it is largely that Mercedes controls the software security functions and without a matching software setup you have no hope of returning the car back to functional order.
Old Nov 13, 2004 | 11:47 PM
SUNILP's Avatar
2015 E250D
No, I really mean it. If you can spare 3 grand, I would not mind getting the system together and testing everything for you. I was thinking of testing this myself at one point also.
Old Nov 13, 2004 | 11:56 PM
miroj's Avatar
The only parts you have to pay yourself would be the new CLK Keyless Go AMG transmission shift and CLK Keyless Go EIS.
With those items in place you have half a chance.
Old Nov 14, 2004 | 12:15 AM
breastroker's Avatar
2003 C230 K , 2001 ML320
Oh no, here we go again, Sunman will have the first Keyless Go
Then Weiderman, then Citron, who next
miroj, do you have the CLK part numbers for the new CLK Keyless Go AMG transmission shift and CLK Keyless Go EIS?
Old Nov 14, 2004 | 12:47 AM
miroj's Avatar
Given that I have a dealer to sign my FDOK for me .....
I am using my friends 2003 CLK 55 AMG - be aware that 2004, 2005 CLK doesnt work on PRE-2004 W203 ..... it's probably obvious but it needed saying.
Here is a sample.
Part Number Designation Code Qty Price
A 203 267 40 11 9C05.....BOOT 117.30
A 209 267 02 24.............FLOOR SHIFT MECHANISM 297.32
A 203 267 22 88.............MODE TOGGLE 56.10
A 209 545 08 08.............IGNITION 234.09
Approximate Total: 704.81 Euro
I would have a guess and say that there is already close to $1000 USD right there. The worst thing is that some of these are DEALER ONLY.
