Cl203 2003 (w203 sports coupe) vibration in drive
Old Apr 8, 2024 | 10:03 AM
Timoste's Avatar
Cl203 2003 LHD - automatic OM611962 2.2L Diesel
Good day lads,
I am experiencing vibrations when I put my 5g automatic gearbox in Drive / Park.
The vibration stops after I start driving 10km+ and I can still hear something rubbing while modulating the throttle, but it goes away depending on how hard I accelerate.
The vibration STOPS once I put it in neutral.
Any help would be greatly appreciated.
Cheers!
Old Apr 8, 2024 | 12:55 PM
Timoste's Avatar
The car accelerates normally, there is no lug, no signs of rpm drop and such, just poor fuel economy (10-11L urban) on the OM611962 2.2L 143 hp engine
Old Apr 8, 2024 | 04:04 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
How many miles? I get a lot of vibration and noise in the cabin.
I need new motor mounts, heck it's 22 years old!
Not an easy job though.
Old Apr 8, 2024 | 04:07 PM
Timoste's Avatar
The gal has 203k km's which roughly is 130k miles.
​​​I doubt it's motor mounts consider it only happens whilst in drive. Even if I rev the engine in neutral there's no vibration like it does in Drive.
G'luck with your mounts!
Old Apr 9, 2024 | 12:06 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Throwing it out there, but on the gasoline models for that era (M271) the alternator 1-way pulley seizes up. They now use a different (updated) pulley. The symptoms are pretty much what you described there. I forget if it happened in P, but it definitely happened in D and R (and not N) with the vehicle stopped. The rubbing/squeaking is from the belt slipping on the pulley.
Not sure about the fuel economy part though.
Old Apr 9, 2024 | 12:18 AM
Timoste's Avatar
Hi Slammer,
Pleasure to see you again.
Speaking of which, I think you are right. I do not really remember it vibrating in P, only in D.
And most likely the same system in on diesel enginess, I'll have that checked
Thank you!
