Power Steering Hose Replacement
Good afternoon All. I am trying to replace the High pressure Power Steering hose on a 2004 C240 4Matic. The issue I am having is removing the E12 torx bolt on the rack. Is there a trick to getting the socket on there? There is a heat shield that seems to blocking access. TIA.
**UPDATE** I was able to get the bolt out and the hose taken off. BUt it seems like the part I took off is different from the one that all sites have as the Part #. Did MB change the design of the hose from the OEM hose??
OGClassic (04-26-2024)
This is the hose i took off
Every site i have searched has given my the new hose number and part.
No its not like that. It definitely has a banjo. Im not sure if MB changed the style due to OEM routing subjects it to being sliced by the pulleys due to how close it is. The new style seems to remove that possibility of it hitting the belts of the pulley. Just hoping for someone to post a picture of it on their vehicle
