Anyone know how to hook up lights?
Old Nov 18, 2004 | 03:21 PM
tedypedy's Avatar
Cars
I've installed a boost gauge and spliced the power for it into an existing fuse under the drivers side panel, but for the light hook up, I'm trying to look for somewhere to hook up the boost gauge so it lights up when i turn on my headlights. As far as I know the lights are controlled electronically, does anyone know where I could hook up the wire?
Old Nov 18, 2004 | 04:28 PM
SUNILP's Avatar
2015 E250D
That's a tough one. The C230's don't have illuminated A/C Vent dials or you can get the light power from there. THe comand/radio/ac controls are all canbus controlled. So is the instrument cluster. The only thing I can think of is the ashtray bulb behind the ashtray or the lighted ring around the cigerate lighter.
Old Apr 1, 2005 | 12:42 PM
bkmotor's Avatar
C230 K
Hello Tedypedy,
I have a C230 sedan would like to know how did you install the boost gauge and where did you locate the gauge ? PM me
Your inputs is much appreciated.
Bill
Old Apr 1, 2005 | 01:30 PM
ctC230K's Avatar
excites your girlfriend
what about the backlit headlight switch panel?
Old Apr 3, 2005 | 09:14 PM
taylor192
Guest
Posts: n/a
Do you want it on with the headlights, or on with the ignition?
I'd suggest using a fuse that turns on with the ignition, simple solution.
