Replacement Key
Old May 21, 2024 | 04:09 PM
skcj213's Avatar
C230
Replacement Key
Hey all. It has been a long time since I have been in this area. My C230, that I have had since 2011, doesn't see a lot of use anymore but my wife loves it so it is going to stay. I have both keys but 1 quit working a few years ago and the one that does work is looking a bit rough. I decided I need to get another just in case. I have always read that replacement keys have to come from MB. I called my local dealership and was told they can no longer get them. Has anyone bought an aftermarket key and successfully gotten it programmed to work?
Old May 21, 2024 | 07:49 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
When I bought my 2005 C230 it only had one key. I searched for options other than the dealer and couldn’t find any. Samcrac recently posted a YouTube video that included a promotion for Car Key Express. He claimed that they offered keys for many cars, but when I entered the information for my car, the only product available was the emergency key. It doesn’t look like they can provide a replacement remote.
Have you called any other dealers to confirm what your dealer told you?
Old May 27, 2024 | 04:36 PM
KevinH2000's Avatar
This popped up on my YouTube feed. Even if they are not in your area, they may be able to provide guidance on the equipment needed to make a key. You could then find a locksmith in your area with the required equipment and expertise.
Old May 28, 2024 | 04:33 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Honestly I'd try bringing the key to someone who knows how to solder. Unless a critical component has fried, the issue you're having is probably caused by a crack in the solder. The outer cases can be purchased online.
Yes, a true replacement key can only be purchased at the dealer. My understanding is that every car has 8 codes available, and the codes are stored on the MB servers in Germany.
The pairing procedure also requires sticking a new "empty" key into the ignition and waiting some 4h. I imagine this is an intentional timed lockout designed to prevent casual theft, much like a safe at a convenience store. A key that has already been programmed cannot be wiped (not using conventional methods at least), which is why a used key purchased online won't work.
