2003 w203 CGW module location
Old Sep 17, 2024 | 05:40 PM
clayg83's Avatar
Hi all. I have a 2003 230 kompressor that has no communication with mostly anything using a MaxiSys at a local shop. I opted not to have them work on it if i can avoid it because of cost. The mechanic says most likely the central gateway module is bad. I had a tree fall on the car and break the sunroof and water may have worked its way into a module. There are no visible signs of water in the car. I did cover it right away but not certain how dry it kept the interior. Any help would be appreciated. I have found on other posts that the CGW is located under the drivers side dash then maybe under the main fuse box. I'd like to have some clarification before i pull the fuse box. Seems like major surgery to pull it out.
