C240 Rear SAM Problem
Old Sep 30, 2024 | 08:46 PM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
After replacing a very dead battery my rear hatch lock cycled continuously, and the rear lights were all on for about 30 seconds as soon as I reconnected the terminal. By the time I got back around to the front of the car it stopped and now no remote locking; car cranks but does not start; display error message on cluster, fuel gauge doesn't work. Obviously a rear SAM issue but, before I send it off, I wanted to try a couple of things that I can't find an answer for.
Is there a fuse or fusible link between the battery positive terminal block and the SAM positive cable harness?
I pulled the rear SAM; if I reconnect the battery and check for 12V with my multimeter between the SAM positive cable and chassis ground, will that possibly fry anything else? I haven't checked continuity on that cable yet as I'm still not clear on which of the 5 cables on the battery terminal block runs back to the rear SAM. Does anyone know?
