C55 amg Crank no start
Old Oct 1, 2024 | 08:23 PM
Amr0_'s Avatar
Here's the situation at hand.
  • Both Sending unit and Fuel pump replaced
  • Brand new fuel pump relay
  • Brand new rear SAM
  • Battery checked
  • CPS on hand but not replaced
The car currently cranks but just can't start no matter what. I hear the rear Sam clicking and everything, but the car just won't start. What would be a next step to check?
Old Oct 2, 2024 | 12:08 AM
S_Holford's Avatar
2003 S55 AMG, 2005 C320 Coupe, 2020 Jeep Gladiator Mojave
  • Battery checked
The crank sensor would've been the first thing I replaced since it's cheap and relatively easy to change. I usually replace them as cheap insurance on any M113 or M112 whenever I buy them because they do fail. Have you tried scanning for any codes yet?
Old Oct 2, 2024 | 01:58 AM
Amr0_'s Avatar
I had codes from the fuel pump but once replaced there are 0 codes. I'll replace the cps and see
Old Oct 3, 2024 | 07:38 AM
Killa' Benz's Avatar
E230 W210
Update? My C230K is also cranking but not starting. Then somedays it will start fine
Old Oct 5, 2024 | 01:46 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Codes from the fuel pump? I had none. One day it just died. Amazingly I was able to
nurse it off the freeway and into my work parking lot several MILES away with just a few PSI of pressure.
So far not replaced the CPS but I keep a spare in the glove box.
Plus a complete toolkit, and a spare coil pack.
As I understand,CPS doesn't throw a code.
Cam sensor will though.
Old Oct 5, 2024 | 11:57 AM
S_Holford's Avatar
That was my experience when I had a CPS failure. Car died, coasted into parking lot, crank but no start, no codes. After the car cooled down, it started back up and I was able to drive it home later that day. I tend to keep a "break down" kit with me too!
