No functions with fobs, and in ignition
Old Oct 26, 2024 | 03:44 PM
DavidW.'s Avatar
So my key fobs are working cause I have new batteries in the main one and Ive tested both of them and with cameras to make sure ir was transmitted, and when inserted in ignition nothing , nothing at all, brand new car battery, I've taken every fuse and tested and also visually inspected and relays so Im at a loss of what to check next , I have all exposed and see the rear sam front sam and all the modules by the rear sam and have wires with plugs that have caps that go no where, idk , it's a 2004 c320 4 matic
Old Oct 26, 2024 | 05:22 PM
112233's Avatar
w203cl
Can you turn the key? If not, your EIS is likely broken. Very often the solder connection to the transmitter coil is broken internally. Lot's of YouT videos out there how to fix this.
